Re: H-governor oil leak
Posted by The Red on August 23, 2000 at 14:35:39 from (12.75.196.10):
In Reply to: H-governor oil leak posted by ralph on August 23, 2000 at 10:34:40:
Ralph remove the top angle plate and disconnect the throttle shaft from the vertical connecting rod throttle shaft.
Remove the carburetor.
Then remove the two bolts that holds the throttle shaft housing to the upper governor connecting rod housing. You will see a gasket and there should be a felt washer under the throttle shaft housing retainer. A combination of an old gasket and worn out felt washer is your source of leaks in that part of the governor.
Post A Followup
: Re: Re: H-governor oil leak
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
