Since the input shaft on the hydro is supported on two tapered roller bearings it has very little room for any movement and no pilot bearing is used on the end of the shaft in flywheel. What shape were the pump vanes, did it bust them up and wedge in there causing the problem or were the bearings loose. It is quite a procedure to adjust the end play on those bearings. I used to actually do it before I mounted the hydrostatic pump on shaft and then you can tell what you have with out spring pressure against them.
