Re: 51 cub 6v to 12v problems
Posted by Tim Epperson on October 12, 2011 at 16:11:30 from (216.170.194.43):
In Reply to: Re: 51 cub 6v to 12v problems posted by CharlieNJ on October 12, 2011 at 15:37:32:
thanks for the reply Charlie. I should have included that, yes the band on the diode is on the alternator end of the circuit which best i remember is correct. Could it be possible that the cub at full throttle still doesnt turn the alternator fast enough to excite the regulator? I am running off the original generator pulley only just as the original generator was run.
