Re: 51 cub 6v to 12v problems
Posted by Bob M on October 12, 2011 at 18:20:51 from (69.207.87.100):
In Reply to: Re: 51 cub 6v to 12v problems posted by Tim Epperson on October 12, 2011 at 16:11:30:
Tim - You can temporarily bypass the diode (place a jumper around it) to test alternator operation. Or bypass the regulator by shorting the tab inside the back like Owen suggests.
However it may simply be the alternator is spinning to slow for initial excitation, as you suspect. Solution is replace the pulley with a smaller one (smallest you can find will be best...)
