Re: M with Heisler od pops out of low side
Posted by Janicholson on October 16, 2011 at 21:29:15 from (96.24.99.126):
In Reply to: M with Heisler od pops out of low side posted by IAJosh84 on October 16, 2011 at 20:11:44:
Three primary reasons for gears jumping out of engagement. The first is wear from use and grinding them in to mesh such that the drive surfaces are tapered in a way that puts force on them toward jumping out. The second is failed detent balls and springs whos intent is to hold the components in place with location control, not direct force or pressure. When the springs rust and or break/fail, the controls can vibrate out of engagement. The third is shaft misalignment or bearing wear that walks the gears or dog clutches out of engagement.
If the linkage is improperly adjusted, the detent system will not be at the bottom of its rest notch. I hope this generic info helps. Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
