Posted by Pat Connors on October 18, 2011 at 10:24:32 from (192.223.136.5):
new 53 Super M (to me) had no compression in #3, and low in all other cylinders. I pulled the head(head gasket had blown and water was in the oil). The # 3 cylinder and plug had never fired. For the few minutes it ran it did not smoke. Should I be pulling pistons?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
