Re: Farmall Super M
Posted by D Slater on October 18, 2011 at 14:01:26 from (184.15.3.93):
In Reply to: Farmall Super M posted by Pat Connors on October 18, 2011 at 10:24:32:
Not that hard to pull the pan and remove the pistons on that tractor when the head is already off. If tractor run with antifreeze going into a cylinder it would pay to check at least that cylinder. When getting compression readings have all spark plugs out and throttle wide open. Have a good starter and battery cranking also.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
