Re: farmall m christmas tree hyd help
Posted by Janicholson on October 18, 2011 at 15:53:24 from (67.72.98.45):
In Reply to: Re: farmall m christmas tree hyd help posted by grandpajohn on October 16, 2011 at 22:03:57:
The two on the left are different from one another.
neither should be used if the CTV is used.
The front one is internally "T"ed to the elbow on the right side. same port different side. It will have no pressure when the CTV is in center position because the CTV bleeds off all pressure to the reservoir. If the CTV is used (pulled or pushed) the pressure will be equal to the pressure in the hoses from the CTV. this causes problems in almost all things you intend to do, as the cylinders could move independently of each other and be out of control through that connection.
The rear Elbow is a delay valved port used only with an implement that has a front and rear lifting setup to allow tillage to the end of the field with the rear gang of shovels. It is also connected to the same initial pressure ports and will give the same type of grief and wrong motion as the front left port.
If there were no CTV the two front valves are used on loader lift cylinders, and the rear left Plugged. on certain cultivators (and other IH implements) the left rear was used in concert with the two fronts to lift the implements in two stages. Jim
