Re: farmall m christmas tree hyd help
Posted by grandpajohn on October 16, 2011 at 22:03:57 from (206.125.159.69):
In Reply to: Re: farmall m christmas tree hyd help posted by D Slater on October 16, 2011 at 04:36:10:
Thanks for all the comments. I worked on it today and looked at the parts book on case's website. I found that the hyd hose was not hooked up from the belly pump to the tree. I hooked one up and it worked as it should.
Now for part 2:
On the left side there are 2 ports that come out of the pump and one on the right. Which side should the hyd hose come from that then goes to the tree to provide the fluid?
Thanks again.
gramps
