Doesn't sound like a shuttle valve problem to me. If it is already moving forward the shuttle valve has moved to it's proper position. I would suspect the problem may be the SR lever is not moving the control valve fully due to wear on quadrant or lever. It needs to pull control valve spool out enough to allow capsules in control valve to ride down the hump and fully seat the balls. I would just try forcing the SR lever fully to the side when advancing it and see if you skip past the problem area. If so, then you need to do an adjustment on valve linkage or repair worn areas.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
