Thanks for another good idea to check. I won"t be able to look at tractor for couple weeks but promise to report back what I find.
I understand your suggestion, but it doesn"t exactly match the problem. Going from nuetral to 1/2 speed works fine. The problem is if I go past it (e.g. faster). When I push the lever slowly only part way past 1/2 way or do so rapidly all the way forward, the result is the same..it stalls for a few seconds, jerks and then functions normally. At least this is my recollection. I will test as you suggest if the clip is not missing as suggested in earlier post
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
