Put perfect circle valve seals on it. They are a bit more expensive, but are found (or equal) on all cars today. They meter the oil into the guide, and are superior to umbrella seals by a factor of 5. It will be a good idea to check the piston ring gap on at least one piston, as well as the piston fit in the bore. If the gap is fine, putting it back together is easy, if it is out of spec, putting correct rings in it will cure oil issues as well. It will also require a light honing of the walls. Check for bore wear at the top of the ring travel with a telescopic gauge, and a micrometer. Compare it to the size at the bottom of the sleeve. Check 3 or 4 directions to assure getting a repeatable number on each cylinder checked. Best of luck to those 4Hers, Jim A 4H leader and past member till 18. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
