I appreciate the recommendation. I will try those.
Do they just go right on top of the valve guide? or do the guides need to be stepped down in any way to accomodate them? how do they "stay put"
This is a 48, so I think the guides are longer than later models... (or at least different in some way that I can't remember right now).
Also while I'm asking questions... I haven't inspected the valves at all yet. I was going to do a leak test with some kerorsene, as well as take everything apart to inspect visually.
But I'm curious what you USUALLY find with valves on these 113 engines - do they typically need re-grinding? lapping? anything?
New guides? New valves?
I realize every engine is different, but curious about what the "norm" is for an original head. Or more directly, if it's a given that I should plan on replacing certain parts.
Seems like you've worked with enough of them to declare what the "norm" is.
Just curious.
Thanks again
(oh - and I already had you pegged as a former 4h-er. And I mean that as a compliment)
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
