Posted by mkirsch on October 20, 2011 at 05:31:26 from (64.80.110.75):
In Reply to: M clutch stuck update posted by Dale_MN on October 20, 2011 at 05:17:23:
On these old tractors, it's rarely more complex than it looks.
I know the bearing engages the pressure plate fingers, but does it actually PUSH them when you depress the pedal all the way?
The fingers look pretty worn, which means the clutch has been in there a LONG time. Don't assume the friction disk is rusted to the flywheel. It could very well be that the pressure plate is shot and is not releasing.
This is a plain M, right? You SHOULD be able to remove the clutch and pressure plate from underneath, without splitting the tractor.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
