M clutch stuck update
Posted by Dale_MN on October 20, 2011 at 05:17:23 from (208.38.113.117):
third party image
third party image
I pulled the belly pump and had a chance to visually inspect the clutch. I'm not familiar enough to know how things should look but the release bearing assy moves easily and engages the 3 levers when the clutch is depressed (pics show clutch pedal released and depressed). I assume that means the friction disc is stuck to the drive plate. Is this a symptom of a clutch that in the near future will need to be rebuilt? Also, the seal on the input shaft for the belly pump has been leaking. It looks like a the seal and bearing are held in place by a casting. Removing the cap bolts and casting would give access to that seal, or is it more complex than it looks?
