Re: M clutch stuck update
Posted by Janicholson on October 20, 2011 at 08:24:52 from (199.17.6.160):
In Reply to: M clutch stuck update posted by Dale_MN on October 20, 2011 at 05:17:23:
The free play at the fingers 9top photo) should be uniform, and the thickness of a popsickle stick (no more). Free playtment is wrong! Do that first. The pedal should move 1.25 inches then touch the T/O bearing to fingers. jim
