I would like to see you use the 93 octane in a 460 ford engine built back in 1970-71 you can not enver feed a 71 383 Mo Par set at the factory timing spec's with out it pigging on light acceleration So i am off my soap box since you are a far better engine builder then I. And OH BTW The highest compression ratio that you can RUN ON THE 93 octane is a ( 9to 1 As per Clevit performance engineers.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
