Farmall h regulator adjustment
Posted by SLH on October 20, 2011 at 17:32:12 from (70.249.209.148):
puting a new voltage regulator on my H is it a good idea to check the point clearence on a regulator if so what is the factory settings I know the voltage should be between 10 to 12 volts when charging. THANKS
