Re: Farmall h regulator adjustment
Posted by pete 23 on October 20, 2011 at 18:10:31 from (74.32.238.142):
In Reply to: Farmall h regulator adjustment posted by SLH on October 20, 2011 at 17:32:12:
You don't adjust point gaps on voltgage regulators as the points are always closed when not running. You can adjust the armature air gap but that is not necessary unless you have had them apart. You adjust spring tension on hanger to change voltage settings. The cut out portion of the regulator does have points that are open but they do not affect the charging voltage, only cut in and out readings. And, normal running voltage on 12 volts system is above 12.8 to 14- 14.5. with the lower reading being a low battery taking a heavy charge and high reading being full charged good battery. Better not to mess with it until you know you have a problem.
