Re: Found the compression problem with the H...
Posted by sflem849 on October 22, 2011 at 17:37:16 from (69.197.84.39):
In Reply to: Found the compression problem with the H... posted by Crazy Red Power in SE-WI on October 22, 2011 at 09:57:39:
I would run it if you already have the head on and torqued once. The H gaskets are cheap and pretty simple to replace if you run into problems again. Those nuts being pretty loose and the ease and cost of doing it again all weigh into my decision. (Not to mention you sound like you already put the head back on. Some wouldn't reuse that head gasket now.)
If you had enough money for the gasket you have enough to get the head flattened out. IIRC my MD and WD-9 heads were $35. Not too bad IMO.
