C, day 1 progress
Posted by soundguy on October 24, 2011 at 17:51:17 from (184.4.159.191):
third party image
third party image
Interesting tractor to work on... got all the way down to the pulley.
still don't see any threads in there ;) hole is only as deep as the nub on the hand crank. still havn't probed it with a pick to see if it's just packed full of 60 year old crusd that is as hard as cast iron.. etc.
also.. a question on how to adjust that fan belt.. interesting setup on that top hose connection with 3 bolts, and the lil track the fan pulley bolt/sgaft slides in. I didn't take the time to try to disassemble it too much.. just took fan off and the 3 bolts out and se it to the side, see there is a nut in a track on back, thus it cannot turn, and then a nut on the front of that.. it didn't feel like it turned either.. so?? give me some hints on that one.
thanks
soundguy
