Re: Carb leaks gas when starting
Posted by Charlie M on October 25, 2011 at 11:45:52 from (74.41.94.226):
In Reply to: Carb leaks gas when starting posted by Jeff338 on October 25, 2011 at 07:57:52:
The old Farmalls do that. They need very little choke and if they don't start right up will leak some gas. Concerning posible manifold issues, you tractor would run poorly if you had a leak on the manifold so if your tractor runs OK when it starts then thats not the issue.
