Carb leaks gas when starting
Posted by Jeff338 on October 25, 2011 at 07:57:52 from (162.57.2.162):
I am having a problem with my M. Whenever I try to start it, if the tractor does not fire and start right of way, gas will begin to pour out the drip hole and I believe the tractor floods. If it starts right of way I don"t have any problems. If not I can"t get it started. I thought something was wrong with the carb so I tried a carb from my Super M and I get the same symptoms. Does any one have any ideas? Thanks.
