Posted by Bob M on October 25, 2011 at 16:57:40 from (69.207.87.100):
In Reply to: Bolster Removal posted by Jim Paterson on October 25, 2011 at 16:34:19:
Jim - Your H engine will safely support itself with both side rails removed. (Keep in mind the engine block - not the side rails - is the actual load-bearing frame member)
When I removed the bolster from my SH I unscrewed the rear frame rail mounting bolts a few turns each and removed the two engine block bolts. But left both rails in place. The rails can be spread a bit the bolster will slide easily forward and away from the tractor.
However there's no harm in removing one frame rail if you prefer. Nor does it matter which side you remove - pick the one that gives you the most space to work.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
