Bolster Removal
Posted by Jim Paterson on October 25, 2011 at 16:34:19 from (107.5.119.152):
I'm going to remove the bolster on my '44 H and a past recommendation was to remove a rail first. I'm going to connect the bolster to my engine hoist and remove a rail as suggested, but I wondered if I need to support the motor from below since the 2 rails are connected to it. Will there be enough support for the engine with a rail removed? (I have the front of the tractor supported on blocks just behind the engine). Also, which rail would you recommend I remove or does it matter? Thanks for your continued support!!!!
