Re: Bolster Removal
Posted by Zachary Hoyt on October 25, 2011 at 17:29:47 from (184.12.64.31):
In Reply to: Bolster Removal posted by Jim Paterson on October 25, 2011 at 16:34:19:
In some ways having both rails on gives you a sort of wheelbarrow effect and makes it easy to roll the front end away from the tractor. I always remove the radiator first in case I lose control and tip it over.
