Re: Carb leaks gas when starting
Posted by Jeff338 on October 26, 2011 at 07:33:10 from (162.57.2.162):
In Reply to: Carb leaks gas when starting posted by Jeff338 on October 25, 2011 at 07:57:52:
I checked the manifold and it has a hole in it. This makes sense to me. The suction at the air intake of the carb is enough to pull the gas out of the carb but not enough to get it to the engine. Therefore it drains out the weep hole. I am going do a temporary fix with high temp RTV and try it this evening. I have also ordered a new manifold as mine is very thin. Will try to remember to post the results.
