Re: how to get a pin out of shifter /housing
Posted by bbbuddy on October 26, 2011 at 14:04:05 from (141.0.9.62):
In Reply to: Re: how to get a pin out of shifter /housing posted by bbbuddy on October 26, 2011 at 13:18:56:
Well the plug was steel (or maybe lead? ) and he got it out, the pin came right out, the shifter was so gunked up he thought there was rubber in there.
He had to scrape it off all over the lower part of the shift lever and the swivel pin and when he put the lever back down into the tranny gears it shifted well. Came back out covered with more very thick crud.
What is the best (easiest) way to clean all of that old crud out of the gears? Hopefully not having to take out the tranny, lol.
The end of the shifter looks fine, but the swivel pin is sloppy, so we are buying that Sloppy Shifter Fix from ebay, thanks for the tip!
Thanks to all who have helped, as you can see we are not used to working on heavy steel...
