656 won't rev up
Posted by tractorcedric on October 26, 2011 at 19:47:18 from (74.36.212.88):
A friend has a 656 that dies when you bring the throttle up. Runs good at an idle. Carb and gas tank have been cleaned. Has new points, condensor and plugs. I swaped coils and that did not help. Found that if I advanced the timing it would rev up a little more. It started doing this all at once. Could the spark advance in the distributor go bad?
