Re: Cub manifold
Posted by gene on October 27, 2011 at 06:06:10 from (66.43.40.73):
In Reply to: Cub manifold posted by skipster on October 26, 2011 at 13:15:47:
Compression - excellent.
Missing: Double check the ignition system and ignition timing.
Also put some Seafoam in the fuel and engine oil. Missing could be partially sticking valve(s).
