Cub manifold
Posted by skipster on October 26, 2011 at 13:15:47 from (76.112.18.13):
I ve been having trouble getting a cub I bought to run smooth.Good spark,I ve put #1 on compression stroke and tried to time it,but all it does is run and miss.compression 120lbs all cylinders.2 diffrent carbs, then I ve tried to rebuild them,no luck so far. But today while tinkering,black liquid I think unburnt gas came spraying out the back of the manifold. It looks like a round hole not a rust hole but I see no plug that came out,is there a plug in the back? I see the one in the front but this other one s smaller like a pin would go in there? Thanks Dick
