Re: Farmall C Rear Axle Gear Problem
Posted by Mike1972chev on October 29, 2011 at 09:09:46 from (99.50.226.189):
In Reply to: Re: Farmall C Rear Axle Gear Problem posted by BoonvilleKid on October 29, 2011 at 08:23:55:
Hoping things are NOT too bad when you get in there!
Just clean her up real good inside.I find a garden sprayer and a mix of diesel and gas,or mineral spirits(using a NON ferous brush) works real well in clean up.Air hose it out in between sprayings.
Place a catch pan under your drain plug and go to town!
Check all your bearings and bolts for torque while your in there.Gotta be a reason those bolts came out ????
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
