Re: Farmall C Rear Axle Gear Problem
Posted by BoonvilleKid on October 29, 2011 at 14:21:18 from (24.206.167.119):
In Reply to: Re: Farmall C Rear Axle Gear Problem posted by Mike1972chev on October 29, 2011 at 09:09:46:
Just got in the house to grab a sandwich. Got the cover off. Sure enough, the washer is laying down there on the bottom of the housing. The forks, rails, bearings, and the gears look to be in very good condition EXCEPT the 4th speed gear is dogeared on the leading edge. I wish it was better but its not so bad it has to be replaced as road gear was working ok before. Now I've got to jack up the axles & shove 'em inward, put the washer & bolts back, check all the torques (like you suggested), clean her out good and then put her back together. I think the only hard part may be getting the forks back in the right place while trying to align the lid with both hands.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
