Posted by teachingscience on October 29, 2011 at 18:21:54 from (209.33.94.227):
Hi all, I put a case loader on my farmall 504 to move round bales. Now that I did all the rebuilding to make it fit, it wont lift a bale. The tractor puts out 1600 psi and the loader has what looks like 2 inch cylinders. I"m wondering if the cylinders are just too small for this pressure or is the pressure too low?? I read some archives that there is a relief valve that can be changed or adjusted ??? Is it in the divider valve or inside the pump housing?? Any advice would be welcomed. Charlie
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
