Posted by bc on October 31, 2011 at 08:39:05 from (68.92.138.225):
In Reply to: 504 hydarulics posted by teachingscience on October 29, 2011 at 18:21:54:
The popoff is probably located on the block on the right side of the rockshaft housing under the seat. Takes a 7/8" socket I believe. They have a factory crimp inside on the thread which makes them near impossible to adjust.
What size and how heavy are the bales you are trying to pickup? Does it sit there and squeel as you try to pick up the bale? How fast does it work when not moving bales? Did you clean the screen and change the filter which affects the fluid flow? What size case loader is it and what is it rated at. 5.5'x6' bales can weigh up to 1500# and not all loaders will handle them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
