Re: H engine valve lash adjustment
Posted by rustyfarmall on October 30, 2011 at 10:33:38 from (216.248.71.224):
In Reply to: H engine valve lash adjustment posted by guyzoo on October 30, 2011 at 10:29:13:
There is no actual spec for cold settings, but 0.020" will be close enough.
