H engine valve lash adjustment
Posted by guyzoo on October 30, 2011 at 10:29:13 from (99.253.138.13):
Hi, I'd like to adjust the valves on my 1950 H, I found the valve clearance is .017 on int and exh when hot, is there any cold spec? Thanks alot
