Hi...I also have a Farmalll 340 that was converted to 12 volts with negative ground. I have not been able to get the gas gauge to work. The 340 tractor was originally 6 volts with positive ground. The positive ground issue seems to be a problem for the gauge. My gauge works fine when I test it off the tractor with a separate 6 volt positive ground circuit. But it won"t work with negative ground regardless of how I switch the wires around. The gauge itself seems to be built just for positive ground polarity. The other thing you need to be aware of is that the sending unit is actually a 6 volt variable resistor and if you give it 12 volts it will burn out. Not a good thing to burn up a resistor inside a gas tank. So, you definitely want to add a resistor to supply just 6 volts, but the polarity issue would still need to be solved somehow. Pete
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
