Farmall 340 gas gauge
Posted by bigr on October 30, 2011 at 16:03:22 from (199.30.168.49):
I"m rewiring my 340 and repairing/replacing gauges, etc. My fuel gauge doesn"t work, but 1 wire goes up to the sender and 1 wire was disconnected. I"m assuming the disconnected wire might be power? Does it go to the switch? The tractor was converted to 12 volts, does the gauge need a resistor? The other gauges (oil, amp, and water) are original and they work.Is there a way to test the sending unit and gauge?
