Re: Farmall 340 gas gauge
Posted by rustyfarmall on October 31, 2011 at 08:16:04 from (216.248.71.224):
In Reply to: Farmall 340 gas gauge posted by bigr on October 30, 2011 at 16:03:22:
The oil pressure gauge and the water temperature gauge are both mechanical. They both operate without electricity.
If the wire from the gas gauge that goes to the fuel tank is still connected where it should be, then yes, the other wire from the gas gauge goes to the keyed switch.
If you have power to the gas gauge, you can test the gauge by removing the wire from the sending unit on the fuel tank, and then GROUND that wire. The gas gauge should then read either completely FULL, or completely EMPTY. This test will indicate a defective sending unit.
IF grounding the sending unit wire has NO effect on the gauge, the gauge itself is defective.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
