Re: cub needle valve
Posted by bc on November 01, 2011 at 21:05:28 from (68.92.138.225):
In Reply to: cub needle valve posted by mike in ohio on November 01, 2011 at 20:28:19:
I think it is those viton tips. If you push them too hard into the seat, then they stick. It can happen if you adjust/bend the float with the tab pushing the needle into the seat while you are adjusting/bending it. I remove the needle, make the bend on the float tab, then reinstall the needle to see if it measures right.
