Re: cub needle valve
Posted by wayne in mn on November 02, 2011 at 08:30:32 from (64.118.12.213):
In Reply to: cub needle valve posted by mike in ohio on November 01, 2011 at 20:28:19:
If the needle will not open without tapping on the side of the carb, I would check to see if the float is rubbing on the side of the float bowl.
