Re: shutting of an A
Posted by pete 23 on November 02, 2011 at 10:31:52 from (74.32.238.142):
In Reply to: shutting of an A posted by charlie M on November 02, 2011 at 08:45:30:
You put on a new shutoff switch. Does it have only one terminal for a wire as it should for a magneto and if so is it properly grounded through paint, rust etc. If you put on a two terminal switch for battery ign you would need to run a one wire to ground, one to mag, and pull switch out to shut it off.
