International 2000 loader on Farmall 460
Posted by slb04786 on November 03, 2011 at 04:24:10 from (74.221.79.122):
I recently bought an International 2000 loader to put on my Farmall 460. Of course it didn"t come with the brackets I need and the rear frame supports had been cut to make it fit on a JD. My questions are could someone with the front brackets take some measurements and tell me what the rise/height is on the brackets? Also, the rear supports were cut and I am not sure if there is supposed to be a plate welded onto the end and adapters made that bolt up to the plate and rear axle or does the adapter tube slide/telescope inside of the rear supports with a bolt/pin going through it. If anyone has an owners manual with mounting instructions for the 460 I would appreciate it if you could email me those pages. I"d like to get started on making the brackets ASAP so I can mount the loader before it gets too cold. Thanks in advance for any assistance offered.
Stan
slb04786(at)gmail.com
