Re: Farmall A timing
Posted by gene bender on November 04, 2011 at 09:34:09 from (67.55.226.244):
In Reply to: Farmall A timing posted by dab102999 on November 04, 2011 at 06:32:54:
Yes like other post said #1 is the one on the front. Now you need to remove the plug so you can look in the hole with a small mag lite then you can see when the piston comes to the top thats when the mag . With the cap off you will see the rotor move now you need to see where the rotor is is line with the cap. I make a mark where the tower on the cap is for #1 which is around the 2 oclock position then as you turn the engine over you will see the rotor go to that position before it fires. the gears driving the rotor can be moved so the rotor is lined up on the cap There is no timing the mag as when it fires on tdc to start the timing will go to 32deg when the engine runs so get the rotor to line up with the tower and thats all theres to it.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
