Posted by tom tylutki on November 04, 2011 at 09:38:08 from (166.137.136.202):
Hi everyone.
So here's the story. Had an engine built for my 1066 about 10 years ago. Old one threw a rod because of a casting issue. Since engine built, tractor never has had to work hard until this year. Put it on a manure pump. Learned quickly that the turbo was bad so replaced that. But here is the issue:
Getting a lot of blow by. Get the tractor under load and if we run it over 1500 RPM she will chug along and then puke oil/fuel mixture out of blow by pipe. Before I start ripping head and oil pan off to check valves and rings, any one have any ideas? Engine is a 414. Fuel pump not turned up (did initially to get around bad turbo but that made her puke more so turned it back down).
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
