Re: Carb rebuild question
Posted by Farmall Paul on August 28, 2000 at 09:45:34 from (209.134.65.162):
In Reply to: Carb rebuild question posted by Skeeter on August 27, 2000 at 20:22:17:
Skeeter, I just rebuilt the carb on my 'H', and had the same problem, only backwards. The thick felt packing in my kit was too big to let the packing nut go in. I read the archives, and it looks like maybe IH had 2 different types of carbs or something. In the end I cut my packing nut down to fit. The folks with your problem used some graphite plumbing string to build up in there. I don't know if any of this applies on your newer 400, but I think it will do the trick. Good luck! Paul+
Post A Followup
: Re: Re: Carb rebuild question
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
