If the loader uses the tractor hydraulic system and doesn't have its own separate pump and reservoir, You aren't getting all the old fluid out. The 560 system should hold more like fifteen gallons. As jimmyjoe said there are three drain plugs, sounds like you missed one or two. Even if you completely drain it and replace the filter, there will still be enough old fluid in the fast hitch cylinder to color the new fluid. The loader cylinders will also hold some unless you drain them separately.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha
... [Read Article]
Latest Ad:
[More Ads]
