milky hydraulic fluid in Farmall 560
Posted by Jim Turner on November 08, 2011 at 22:26:35 from (74.136.134.157):
I recently bought a 1958 F 560 with a loader. It had bad bucket cylinders - gushing milky hyraulic fluid, I had the cylinders repaired and was advised to purge the system to eliminate water contamination. I drained the system -- it had only two or three gallons. Not wanting to waste money, I twice cycled the system with fresh fluid -- once with 7.5 gallons and a second time with 5 gallons. The hydraulic fluid is still milky. It occurs to me that the system is probably putting air into the fluid because it is low on fluid making it milky.
I would like to know what someone more experienced thinks before I put 16 gallons of Hytran in the system. Thanks. jim
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
