Re: milky hydraulic fluid in Farmall 560
Posted by RPM1941 on November 09, 2011 at 08:44:18 from (173.24.196.59):
In Reply to: milky hydraulic fluid in Farmall 560 posted by Jim Turner on November 08, 2011 at 22:26:35:
If you are using the tractor hyd system, that is no added hyd valves or pump driven by PTO, you must drain out all Hytran in the tractor, this includes the TA/clutch/hyd center housing & the rear housing for transmission + differential + axles. This refill takes at least 15 gal. It should take additional Hytran if its has double action loader cylinders, they must be purged from both sides also. The Hytran circulates between these systems freely.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
